Playing/capuring from Sony HDR-HC3E
  • Playing/capuring from Sony HDR-HC3E
    By using the SHX-E1 DV input I don't see any picture on the monitor. I can Play, rewind and and so on from Edius, but no picture.
    Trying the same thing by using a Generic HDV input, everything is fine.
    My display adapter is a Nvidia FX 3500.
    What shall I look for to get a monotor picture by using the SHX-E1 DV input?
    S
    Generic HDV input is the correct choice for HDV.
      If you are using a DV input you will need to set the HC3E iLink Conv to DV.
      Roger D
