Output audio Track to CD?
  • Output audio Track to CD?
    I'm using Edius 4.6 Can anyone tell me whether it is possible to export the audio track from a project to CD . How?
    Yes. Print the timeline to a PCM(WAV) file, then open that file in an audio editing application (Sound Forge, Audition, etc) and downconvert to 44Khz (from 48Khz) 16bit Stereo. Then use that program or another program such as Nero to burn the track using an Audio CD template.
      Thanks Dave, works great!
        if you are using Nero Burning Rom, it will convert the 48k audio automatically to 44.1 during the CD burn process
          Yeah but I don't trust Nero. I use Audition or Soundtrack Pro (under OSX) and both have anti-alias filters for up/down converting audio. For burning Nero is fine.
