I shoot in HDV (Sony Zu1). My end product is a SD 4x3 DVD and a SD 16X9 DVD.
Currently, I have been capturing the HDV 10801 then changing the settings to SD 16X9 and out putting that project. Then I go back and change the settings to SD 4X3 and out put the second project changing each clip one at a time to 4X3 with the layout tool. The projects are about 1.45 hrs long and just barely fit on the DVD at the bit rates I am using. So you can see I have a long wait when using 2 pass encoding in Procoder. To encode each project project it takes about 3 hours. Then I have to author each project seperately and wait for the master.
This is a weekly project for me and usually takes one whole day to just do the encoding and burn the masters.
I tried to export the 16X9 project to an avi file then change it with the layout
tool. However, since the project are almost 1.5 hours long that introduces another long wait.
I want the best SD dvd I can make and I have read where others are editing in HD then repositioning the titles in SD.
Is there an easier way to do it?
Thanks guys and gals you never let me down.
Ronnie
www.dirtracingvideo.com
Ronnie
