Basic Audio Question
  • Basic Audio Question
    I finally received my new Edius laptop and have been experimenting and learning the software for a day or so. I do have a basic audio question. When I have a clip that I want to bring down to the timeline I would like to be able to use (see) both channels of audio in stereo (I have two stereo audio channels). I can't figure out how to accomplish this. If I right click on 1A it gives me the option of Stereo Channel 1,2. That seems to be bringing both audio channels to one audio timeline. I would prefer to be able to split the audio so I can manupulate each stereo channel independently. Ideas?
    David
    David
    DMS Films, New York
    Desktop - Edius 5.5 / Intel i7 975 Quad Core 3.33GHz / 12GB DDR3 1333MHz / Nvidia GeForce GTX-275 / Vis Title 1.1 / FireCoder-Blu / (2) 27" LCDs / JVC DT-V24L1U (24" 1080p) / Windows Vista 64 - www.EditHD.com
    Don't know if this helps but if you click on the VOL button until it changes to the PAN rubber band control. This gives you L and R channels.
    Tony
    Tony
    Asrock Z68 Extreme7 --i7-2700K --EDIUS 8.5WG--HDStorm+ --16GB Kingston HyperX--GTX 560Ti--AX850 PSU--MxM PCI-e Reader--Win 10 Pro 64bit
      Tony,
      Thanks for your reply. i tried what you suggested however I'm still only getting audio out of one speaker for each audio channel. I must have a setting incorrect or I'm doing something wrong?
      David
      DMS
      David
      DMS Films, New York
        2 channels split:
        1 right clik on 1A an choose Mono 1 1
        right click on 2A 2 2
        or:
        2 map project to bring audio down to ch 1 to A1 and CH2 to A2
        or
        Save Preset with V track only with audio to A1 and A2
        or right click on any track go to properties and choose mono 1 or mono 2 depeding on what you want to hear.
        Look in my sig nice link to edius training
          Steve,
          I tried your first suggestion. The problem is it does bring down both audio channels but I can only hear each channel through one speaker. When edited with My Canopus Storm system what i used to do in the same type of situation was to right click and copy left or right and that would give me stereo on each track and then I could set my levels. I still think there must be a way to do this. Suggestions? Thanks.
          David
          DMS
          David
          DMS Films, New York
            1 alt+ enter on the track on A1
            choose mono 1 on the audio on track 1
            2 alt+ enter on the audio on 2A chose mono 2
            see picture
            or
            Map the output of the sequence so that:
            A1 goes out to 1 and 2
            A2 goes out 1 and 2
            see picture
              Steve,
              Thanks for the reply. It's finally working! It's funny how even the most basic task can be tricky (sometimes) when learning new software.
              Kind regards,
              David
              DMS
              David
              DMS Films, New York
                If you visit the Edius training site there are some how to documents. I I remember correctly Kenneally did a nice document on audio mapping/ channel selection.
