how to import animation clip to bin window
  • how to import animation clip to bin window
    Hi Everyone,
    How do you import a animation clip to the bin window to use on
    the time line? The animations are avi files.
    Any help would be appreciated!
    Thank's
    Mitch-K
    what seems to be the problem? does Edius give an error when you double click the bin in an empty area and browse for the animation?
    or does windows explorer give an error when you drag from explorer to the bin?
      If your animation is in a valid avi format, just double click the bin, window opens, look for your avi file select it, drag it from the bin to the timelime, play it.
      Also you can use windows explorer to drag & drop, that simple.
        It would help us to know what format the animation is - AVI is merely a container - is it uncompressed, DVCPRO, DV, etc?
          How to import animation to bin window
          Hi everyone,
          I would like to thank Soundfreak, for his advise on clicking in the
          bin window and opening up the animations then applying them to
          the time line. It worked!!
          Thank's Anton and Kenneally for your input!
          All the Best
          Mitch-K
