I have loaded a couple of short 24F clips on to the timeline. The clips came from my FS-C (XH-A1 camera). When I go to test a DVD under the print menu in Edius the "Print to DVD" is greyed out. When I try the same thing with HD clips there is no problem...it burns a DVD.
Print to DVD greyed out
Please try a search and you will come up with several threads such as this one that will answer your question http://ediusforum.grassvalley.com/fo...int+DVD+greyed
Are they in a 23.94 project? If so, bad news. The project needs to be 29.97. :~,(Rusty Rogers | Films
Yes, it should.
You can put your 23.94 footage in a DVD compliant project and burn also. Edius is not fussy in that way. :~)Rusty Rogers | Films
