dvd fail to burn to disc in dvd creator
  • dvd fail to burn to disc in dvd creator
    Hi Everyone,
    I am having a problem burning a dvd from the time line using dvd
    creator. I have no chapter markers on the time line. I am doing just
    a simple burn to dvd with only one menu as a start button. When
    I click on burn, I get a message saying failed to encode. I am using
    Edius 4.5. I am new to Edius and I like it very much. If some would
    help me with the right settings in dvd creator I would very much
    appreciated!!
    Thank's
    Mitch-K
    is your project setting on standard def with interlacing, this is required for DVD creator
      dvd creator failed to encode
      Hi Anton,
      Thank's for your quick reply. My settings are Generic OHCI SD NTSC
      720X48O 59.94i 4:3 48KHz. I get a message saying failed to encode
      when I click the burn button.. Any help would be appreciated!!
      Thank's
      Mitch-K
        Why not burn from the timeline using ProCoder Express? That is what I do; I also make it an autoplay dvd with chapter markers. You can then jump from one to the next using the skip function button on your dvd player.
        DVC laptop: W870CU i7; 17.3" 1920x1080; 2x 1TB 7200rpm SATA notebook drives; Edius 8.5WG; Windows 7.
          Originally posted by Mitch-K View Post
          Hi Anton,
          Thank's
          Mitch-K
          did you mark in and out on timeline prior to clicking print to DVD
