System Frequency
    Originally posted by GrassValley_BH View Post
    If you have a different machine with EDIUS, you can download the EDIUS demo and try it on that. That should give you a clean environment (EDIUS-wise) to test on.
    Except if the data is VariCam (which I suspect it is, with the funky frequencies) - the demo won't let you use VariCam content. It will only load the audio data. (ie. appear as an audio clip in the Bin window)
      Good point... if it's VariCam, no-workie with demo.
        My first thought was that it was a 2:2 pulldown issue, and that the program was reading the pseudo interlace files as prog or some such. However they were mostly varicam files but not all, actually I was purposefully shooting a straight 'filmcam' progressive 720/25p and even a native 25pn file as controls.
        The only linking factor is the system frequency...
        I'll keep those particular files til I get home in a couple of weeks, get Edius anew and try them, that will pin it down to a corrupted version of the prog.
        BTW I am in Pakistan, not much works here as it should!
