Capture trouble 4.61
  • Capture trouble 4.61
    I'm trying to capture Generic HDV input from my Canon HDV 30 and I can't get the capture icons to light up.
    My settings are:
    Video Frame size : 1440 x 1080
    Frame rate : 29.97( 30000/1001 )
    Pixel aspect : 1.3333
    Field order : Top Field First
    Audio
    Rate : 48000Hz
    Sample size : 16 Bit
    Channel : 2
    Setup
    Rendering format : Canopus HQ AVI
    Over Scan Size : 3 %
    Be sure the Canon is not down-converting the footage.
    Edius expects to see an HDV VCR. If you feed it DV it won't work.
    I set Overscan to 0% (it tells Edius how to handle some of the older transitions)
      You guessed it Rusty, thanks. I was trying to feed it DV.
