Audio problem
  • Audio problem
    I have problem with audio levels, ex 1VA track with voice and 1A track with backgound music, when editing all hear ok but when export to mpg background music level automaticly go up if no voice and down if have. How to make fixed background music level, how to export what hear or how to regulate that automatic up down mix or how to hear that when editing???
    That is very strange. Sounds like some kind of automatic gain is enabled.
    Can you export the MPEG file, and play it back in Windows Media Player?
      Im using KMplayer but yes, on finished DVD same problem
        Can you try playing it on another system? EDIUS shouldn't be doing any level adjustment, but it's possible that your MPEG decoder is.
          I try some VST plugin to control volume of backgound track, same problem
            Mpeg generic encoder maybe cause this problem??
              I try on another PC thanks for sugestion
