Question about pce and H.264
  • Question about pce and H.264
    Hi
    I have a question about quicktime export....
    I export as H.264 it is fine, but in procoder express I can´t choose optimize for streaming, just for download, is there some settings i missed....
    Could be great if someone had a solution
    cause you can change the *.mp4 to *.flv...so it could be use in flash players
    A computer with a lot of stuff in it :)
    Hi Ludde
    You should see 3 options in the encoder. choose "quick time export file" then when you get to the "job summery" page click "output advanced settings", choose Quick Time Movie in "select exporter" then click "modify exporter settings", you should now have the "movie settings" page where you can modify video sound & streaming values. Under video--> settings--> H264 you can remove check from auto to open selection of streaming in the data rate dialog. (not sure if this is what you are after) also you can make more streaming decisions from the streaming section of the "movie settings" page.
    HTH
    Dave.
    www.nakedeyedv.com
      I tried it...but the resulting file gets very pixelized when i choose streaming ?
        Can you post your target settings & source file type & ill see how things look here.
        Regards
        Dave.
        www.nakedeyedv.com
          Hi Dave
          I do it all from the timeline, my source file is hdv 1440*1080i 50i.....
          I try to attach some files
            Try this:
            You should be able to optimize for streaming in the last dialog.
              Thanks Thoff....
              That worked great wiht video....but i don´t get any sound when playing it with a flashplayer..so where am I going wrong ?
              I have sound with vlc player
                Which audio codec are you selecting? It sounds like you're using one that's not supported by the Flash player, you may have to experiment to find something that's compatible with both players and gives you good quality without requiring too much space/bandwidth.
                  I tried them all...didn´t get it to work, but however I got it to work when I raised the datarate in the Mp4 , H.264 window, then one I attached, I got great results
