I assumed one could select a bunch of avchd clips and drop them on the converter icon. Doing so causes nothing to convert.
One at a time works fine, but is totally impractical.
The entire CANOPUS converter needs to be replaced by a browser like the one in FCP. You need to be able to view -- play and scan -- ALL clips and then choose only the ones you want converted.
PS: as i remember, the player doesn't accept multiple clips either,
