Hello
I am using Edius 'DVD Creator' to produce DVDs (or at least output files for later burning). All is well when I use constant bit rate video, however, there is a sync problem between video and audio that gets worse towards the end of the DVD whenever I switch to variable bit rate video.
In both cases I have restricted the overall bitrate (video and audio) to less than 8 Mbps.
Some technical details:
- using EDIUS 4.61;
- overall length of timeline: 2:27:00 h;
- CBR test: 3.7 Mbps video rate, 256 kbps audio rate (AC3);
- VBR test: maximum 7.6 Mbps video rate, 384 kbps audio rate (AC3);
- viewing DVD files using 'MediaPlayer Classic' (a great open-source media player available from here: http://www.afterdawn.com/software/vi...9_1__20080127_).
Looking at the temporary 4.5 GB mpg file generated in the DVD_Temp folder (together with the IFO and VOB files in the VIDEO_TS folder) I note that there is no sync problem whatever video bit rate type I use. So where is the problem ? I expected where video and audio are contained in the same VOB file there should be no possibility for sync problems.
As the timeline is more than 2 h long I'd much rather use VBR and CBR as the image quality appears very slightly better when using VBR.
Any advice much appreciated,
hokoall
- using EDIUS 4.61;
hokoall
