Analogue Audio Capture
  • Analogue Audio Capture
    anybody help! I can't find how to make an analogue audio capture without capturing video! I have Edius SP for HDV hardware and v4.61 sw. I have hooked up my old Compact Cassette Dec to Analog In Ch1 and Ch2 to digitalize some old cassette. But... how...
    I tried to search on this forum but did not find anything.
    application settings, customize
    add audio capture button to player controls, next to the normal capture button
      Hi,
      One other point that is often missed. To capture audio only via the bay or direct into card has an unfortunate requirment. The anologue video socket (yellow) needs to be supplied with a video signal even if it is just connected to a camera or in my case I connect the out of one bay to the in on the other and fire up Edius on both, then use the button that Anton mentions.
      Keith
      Dual 3.06 Xeon, 2Gb memory, NX card, Edius 4.6, Procoder 2.
        And that's because the audio is embedded in the analogue video signal.
          Hi,
          Just to clarify - this applies to any audio signal coming from a cd/dvd player as well. As long as there is a video in signal Edius will capture the external sound from a non video source
          Keith
