PowerDVD and Edius 4.61
  • PowerDVD and Edius 4.61
    I tried to put Power DVD 8 onto my E4/NXe system. It seems that any version I install creates an error message whan I play a DVD but NOT a media file.
    Seems Edius related - does not happen on identical System with Storm/E3.6
    DD
    I had PowerDVD8 on my 4.61 PC and it worked fine, apart from the fact that it has become bloatware and requires constant internet access and constantly wants to review my movies and all sorts of crap, like asking if you wish to resume or start from beginning, I NEVER WANT TO RESUME
    so I uninstalled it and installed PowerDVD7 and I am happy
    I also tried Corel WinDVD but its playback drops frames on a regular basis, very noticeable during camera pans
    uninstall powerDVD8 and then clear the temp folder and install it again, then it should work
      Have you considered turning the prompt off? There's a checkbox in the dialog that asks you if you want to resume or start from the beginning. You can also set your preference in the Configuration -> Player dialog.
        yes, I have done this in PowerDVD7 and it works perfect
        in PowerDVD8, you can't disable this feature, I wrote to support and they told me that I can't disable it and that I also can't disable this totally stupid Movie Remix rubbish
        PowerDVD5 was the greatest player ever, it opened all movies at their native pixel resolution
        all versions after that fail to do so, that software has gone downhill
          I tried clering the temp folder and installing 6 my old version - same problem. Why the error relating to Edius?
            I just installed it again on the 4.61 PC to be sure and it works fine, now I uninstall it again
              I have been using powerDVD 8 and you can turn all that prompt stuff off, there is a setting that you use to disable it, I never get pop ups ect ect with version 8 Anton.
              Cheers
                Cheers
                Hi Steve
                do you have a version other than the standard version
                even their tech support confirmed to me that I can't disable the resume feature and the MoovieLive rubbish
                  Hi Anton,
                  I am useing the Ultra version of PowerDVD 8, Which I think is there top of the line version for the program,
                  cheers
                    I just realised that "Edius" was the user name that was used on a user config. ....but now I cannot reistall as something is corrupted- happy days.
                      aha, maybe I need to upgrade
                      what about the size of the movie when you open it? does the player open according to resolution of the movie like PowerDVD5 did or does it open at an incorrect resolution like 958x522 etc
                        seems to open to the size of the movie Anton, I have it set to open at full screen but this can be changed in the settings, I have just installed 2 ATI 4870 Graphic cards in crossfire mode, and played back a Blu ray in full HD no problems.
                        cheers
                          Hey Steve, how are the ATI 4870 cards going? Can you get true HD out of the HDTV port yet?
                            in my case, all standard def DVD's made from Edius open at the wrong size in PowerDVD8 but they open perfect in PowerDVD5 or earlier
                            so the problem is not an Edius problem
                            and sorry for hijacking thread DD, I am done now
                              Hi John I will be testing them on Friday and will let you know, but so far everything is great with them...
                              cheers
