I've imported a Quicktime file to a project that is set to SD and 4:3. For some reason I am not getting any audio. I took the same Quictime file and using Procoder I was able to convert the Quicktime file to a Windows Media file 1/6th the size and the audio played. What's wrong with Edius here?
Quicktime import....No Audio
I am using Quicktime 7.4.5 and Edius 4.6.1.
Since a few months ago I have been having problems with Quicktime.
Lauching Quicktime brings up an error message:
"This application has failed to start because vafxu.DLL was not found". Re-installing the application may fix this problem".
After searching the internet and trying all kinds of apparent fixes I finally gave up. Quicktime finally launches after hitting the OK button a few times.
Will changing the Quicktime version allows for the audio to work when I drop the file on the timeline?
I did try the exporting of the audio file.....it does work! Thanks
