How to add new fonts to Quick Titler
  • How to add new fonts to Quick Titler
    Hi every one I am new to Edius, I want to purchase some fonts to add to
    Quick Titler. Is this possible, If so how to do this. I do not like some of the
    fonts that came with Quick Titler. Thanks..
    Just add the new fonts by way of the font icon in the control panel.
    After installing the fonts, reboot, and all should be well. Unless, of course, that QT will not accept the font for some reason. Unlikely though!
      Is the ability to add fonts via the the font icon on the control panel still available and in EDIUS 6.51?
      I cannot locate this, nor does it seem to be in the manual.
      Thanks,
      Carlton
        right click the font you wish to install and then click install font
          Thanks,
          Carlton
          It has nothing to do with Edius or Quicktitler, it is a Windows thing
          The fonts used by Quicktitler are the ones installed in Windows
          Hope that helps
          Regards Barry
            Be sure to re-start Edius for the newly installed fonts to appear.
              Installing fonts
              Thanks Rusty, I had been banging my head for an hour before seeing your tip.
              Barry Weare
              BW Videofilms, Berkshire UK
              Edius 5.5, Win7 Pro 64bit, 16GB RAM, Intel Core i7 2.8GHz, NVIDIA GeForce9600GT, 5x 1TB SATA II (24/7 WD Enterprise type) with 4x in Raid1 for video, 1x for system/utilities.
                Yup, true for most applications.
                Hope your head heals.
                  Get in the habit of re-starting either the OS, Windows, or both. I am old school when building a machine. Everything that is entered gets a reboot.
                  This method goes back to the early 90's. It has yet to fail me.
