Installing Titlemotion Pro
  • Installing Titlemotion Pro
    OK....so I have a new computer and ready to install my full Edius setup. I am trying to install TMPro and it is asking for the Previous Titlemotion disc from version 3. I have disc 2 laying around but for the life of me I can't find the Titlemotion Pro disc 1.
    I asked before if there is a way around this and the answer was no. Please tell me there is a way now to get it installed. I use TMPro all the time and have projects with TMPro titles in it. If I can't get it installed it means I can't use the new setup for any work on those projects.
    With all the new "love" from GrassValley for Canopus I am hoping there is now a way to get TMPro installed.
    Help!
    OK....I feel dumb yet again. I was using the wrong Edius V3 CD. I found the right one and all is well.
      shot in the dark......
      my TM-Pro (who shipping with Edius3.0) have the name Disk 2
      and on it, is all for TMPro...
      I have never saw a TM-Pro Disk 1
      it is imhho eventually only a CD-print issue, and the Edius-CD owes the printed name "Disk 1"
      but it is only "Edius" named and printed.....
      if your windoof-explorer bring the same result as my pictures.......start the "SetupManagerFor TM.exe.
      please, excuse my "gibberish" english .... old "vienna" Hans
        I used the old Disc 2 in installation. Titlemotion Pro looks the same in Edius 4 as it did in Edius 3. What's the difference in the two versions. The version info under help says TitleMotion Pro 36. Is this the correct version for Edius 4?
        Pam
          Pam
          Pro36 is the correct version
          there are several bug fixes since the Edius3 version, the rest looks the same
            Thanks for the help. Truthfully, I just installed Edius v4.10, thinking I was getting v4.5. I have a current project that would benefit from AC-3 basic authoring from the timeline. oh well...
            Pam
              use effect ?
              hi,
              i want to use pagepeel effect in PIP Clip. so please advise me how can i do this..? just like we can PiP Disolve in pip clip. please reply ([email protected]) and another quastion is i use edius 4 and i have xplode profesonal 4. i want to install xplode pro. software. but it doesnt intall.
              thanks,
              manoj
                Help!
                hi, i m manoj from india.
                please install first edius and then after install tm pro.
                ([email protected])
                manoj
                  There is an XPlode Pro for Edius v 4.50 you can download from the website.
