audio delay
  • audio delay
    I've a problem with my Edius 4.54. I edited a sequence and everything was OK. When I do play the video and the audio start together, but some seconds after there is audio delay more and more promonounced. If I stop in an other point start the sync again but after some seconds again the same problem.
    I need your help. Gratefully. Iosi
    How are you monitoring your audio? That sounds like a case of watching a computer playback but monitoring audio through an external setting
      Where do you wach the picture, External or on the PC monitor ? if external like tv monitor, from what output on the pc ?
      And from where do you output the audio, from audio card or ?
      JoiCam´s
      And more
        this can also be caused if the audio is not wave at 48khz
          I think i did read your post in to much of hurry last night and missed the point.
          some seconds after you hit the play,all is fine from the start, then audio delay begins fiew sec´s after that and get´s more and more delay fruther you play the timeline.
          I think Anton is right.
          Try exporting the audio to 48khz and put it back to the timeline.
          My best
          Johannes
          JoiCam´s
          And more
