I have a new computer with Windows XP SP3 (Before Vista SP1). Plate ASUS P5E3 Professional Workstation DDR3 1333mhz 4GB, CPU Core Quad QX9650, Nvidia 9800GX2 graphics card, RAID 640GB hard drive and power supply of 1000 W. I have installed the card and board Edius NX PCI-X 64 bit, bus and 32-bit PCI bus card for HDV, software Edius 4.61 HDV 1080 / 5 0i framework with 1440x1080, EDIUS I am not working properly, I for error and gives me: "pci bus busy occurred." The video will realentiza me, for many times what I try not working properly. With 720x576 DVCAM working properly. Do What can I do to go well for HDV 1080? Thank you
Tengo un ordenador nuevo, con sistema operativo Windows XP SP3 (Antes Vista SP1). Placa ASUS P5E3 Workstation Professional DDR3 1333mhz de 4GB, CPU Core Quad QX9650, tarjeta gráfica nvidia 9800GX2, disco duro 640GB RAID y fuente de alimentación de 1000 W. Le he instalado la tarjeta Edius NX y la placa PCI-X 64 bit, de bus y PCI 32 bit de bus tarjeta for HDV, software Edius 4.61 HDV 1080/5 0i con marco de 1440x1080, El EDIUS no me funciona correctamente, se me para y me da error: "pci bus busy ocurred!". El video se me realentiza, por muchas veces que lo intente no me funciona correctamente. Con 720x576 DVcam funciona correctamente. ¿¿Qué puedo hacer para que vaya bien para HDV 1080?? Gracias
