component switcher to use with Edius NX
  • component switcher to use with Edius NX
    I have two NX machines and one monitor. I bought a cheap switcher and it failed. It just would not handel a 1080i image. SD images would switch between the NX out puts but when going to HDV settings in Edius/4.61 the top of the image was schewed.
    Any recommendation of a resonable priced switcher that will work with the HD component signals coming from the NX cards?
    Ronnie
    Ronnie Martin
    Kato Video Productions
    luckily, my monitor has 2 component inputs
    video only or does it also need to switch audio?
      This is what I use. Works great and only $19. My inputs are Edius NX, Sony HDV deck, and Cox HD cable TV. Output to a 20 inch Vizio HD TV. I got mine from Digital Media Source via Amazon but there are a number of folks that sell them just do a search on "4 x 1 HD Component AV Selector"
      Jim Edds www.ExtremeStorms.com
      Edius 5.51, I7 980x Hex Core, 3.33 GHz, 12GB DDR3, HD Spark, 250GB SSD, Win7 64 bit, 4x2TB RAID 5 eSATA array (200-225mb/sec), 4 hot swappable internal SATAII misc.. drives; Cams: Panasonic AG-DVX200, Go Pro; Edius 5.51/HP 8710W & 17 in mid 2010 MBP/Adobe CC suite.
        This is what I use.
        Inday.com, Video/Audio switching and distribution. Proven professional grade products for signage, broadcast, media and home theater.
        _________________________________
        Triple boot:Win10Pro/I7-5930K/GTX780/SSD-RAID/HDD-RAID/10GbE Intel X550/BMD 4K Extreme 6G/32GB RAM
        Triple boot:Win10 Pro/I7-6950X/GTX1080/SSD-RAID/HDD-RAID/BMD 4K Extreme 12G/2 x 10GbE/64GB RAM
        both on: 10Gbps Media sharing Network, 10Gbps NAS
          Hello Anton: My monitor has a component pass through. So the out put from my NX cards goes to a switcher then to the monitor and the pass through goes to a HD TV.
          My monitor is a 20 inch d) but with a manual or auto selection feature and it would not pass the HD signal cleanly.
          I took the old one apart and sprayed the contacts and for a little while it is working. However, I am sure I will need something more rugged. It was all plastic inside and had some funny looking switches that kept sticking.
          Thanks guys for your help
          Ronnie
          Ronnie Martin
