Xplode Pro 4.60
  • Xplode Pro 4.60
    Hola, tengo target grafica nvidia 9800GX2 que tiene problema de Xplode Pro 4.60 para edius nx for HDV. Se cuelga y tiene la configuración mal, porque el overlay es de color verde. Gracias
    Dear sirs, I have a card nvidia 9800GX2 that has some problems for Xplode Pro 4.60 for edius nx for HDV. It does not run and the overlay is in green color. Thanks!
    Dear Sergio, all the new nVidia-based cards are not supported by renderer of Xplode Pro and Xplode for Edius. If you do not want to switch to ATI card, the only option is to change your Xplode settings to software render- there is no realtime if you use that option, but at least, you will be able to work with Xplode's in Edius.
    mike
    Asus P8P67, Intel i7 2600K working at 4.50 Ghz, 16Gb Kingston RAM, Windows 7 64bit, 500Gb system drive, 320Gb Data drive and 1TB RAID-0 for AV, Edius NX Express, EVGA nVidia GTX 570 2.5CB DDR5, 750w ALTEC power and some creativity...
