Just downloaded the new v. 2.0 XDCAM-EX Clip Browser and now the "XDCAM-EX Clip Browser" option is no longer present under capture (in Edius Broadcast)- I uninstalled it and installed v. 1.01 and it is back. Does this require a fix by GV/Edius?
XDCAM-EX Clip Browser v. 2.0 and Edius Broadcast
VIDEO WORKSTATION: Dell T7910, Dual Xeon 10 core CPUs, 128GB RAM, 512GB SSD (OS Drive),12 TB Video Drive (Raid 0), Dual NVIDIA GTX Titan X graphic cards (12GB), Blackmagic Decklink Extreme 4K card
MOBILE VIDEO WORKSTATION: Dell Precision 7710, Xeon E3 1535, 64GB RAM, 1 TB PCIe NVMe system drive, 2- 1TB PCIe NVMe drives in RAID 0,4K UHD Display,Nvidia Quadro M5000M,Tags: None
Originally posted by planetweckesser View PostJust downloaded the new v. 2.0 XDCAM-EX Clip Browser and now the "XDCAM-EX Clip Browser" option is no longer present under capture (in Edius Broadcast)- I uninstalled it and installed v. 1.01 and it is back. Does this require a fix by GV/Edius?Jerry
I believe it's related to where the application is installed (i.e. folder path and folder name)
So I'd suggest you make a note of the full path and name of the clip browser software and then use that same naming for the new software. Where did you get that software, btw? I'll pull it down and test it myself. :)
I have the same problem.
You can still drag the clips into Edius but it doesn't show up in Edius tools at all.
I installed it into the same folder as version 1.
Cheers VaughanMain Edit System ASUS Z170-Pro, 6700K, 32 gig ram HD Spark, Windows 7 64bit Edius 8.1 (Edit Machine)
Seems to be much quicker to use, in that it finds the folders and files MUCH quicker on startup, and much better layout.
Originally posted by GrassValley_KH View PostI believe it's related to where the application is installed (i.e. folder path and folder name)
So I'd suggest you make a note of the full path and name of the clip browser software and then use that same naming for the new software. Where did you get that software, btw? I'll pull it down and test it myself. :)VIDEO WORKSTATION: Dell T7910, Dual Xeon 10 core CPUs, 128GB RAM, 512GB SSD (OS Drive),12 TB Video Drive (Raid 0), Dual NVIDIA GTX Titan X graphic cards (12GB), Blackmagic Decklink Extreme 4K card
Unless Sony haven't quite finished prepping this update (ie. why is it only available on the Canadian site and nowhere else?), then we will probably have to patch EDIUS.
No idea how long that will take (or if it will even happen in 4.x's life). It's no showstopper for sure, as it's simply referencing something from the Windows Start Menu anyway. :)
