4.6 pro to 4.6 broadcast?
  • 4.6 pro to 4.6 broadcast?
    is it worth me changing my current set up which is e4.6 pro with storm 2 to broadcast 4.6 with storm 2
    are there any real advantages to the upgrade?
    the only difference is the support for the following formats
    Thomson Grass Valley Infinity™ JPEG 2000
    Panasonic DVCPRO® 50 and DVCPRO HD
    Panasonic DVCPRO P2
    Panasonic VariCam®
    Sony XDCAM®
    Sony XDCAM EX
    so if you dont use any of these formats you dont need Edius Broadcast...
    Aristotelis Bafaloukos
    BEng (Hons), MSc, MBCS
    Ctrl+Alt+Delete
      thank you for that it will save me some money
      btw do you know if there will be a 4.7 that supports storm 2
        It seems unlikely that there will be a v4.7 because v5 is said to be appearing before/by the end of this year. It is also said that v5 will not support the Storm card.
        DVC laptop: W870CU i7; 17.3" 1920x1080; 2x 1TB 7200rpm SATA notebook drives; Edius 8.5WG; Windows 7.
          There are no plans for a v4.7 update at this time.
