Exporting/File size problem
  • Exporting/File size problem
    Hey guys, im running into a problem again, ive been using edius to do a few pans and zooms with on some photos, i used 33 photos, their all 1920x1080, and it comes to 13mb for the JPGs, but when i do all my stuff in edius, i wanted to test something real quick so i export it as an wmv it comes to 210mb for 7 seconds of video.......... im trying to figure out why its not like 15mb any help is appreciated, thanks
    im using the windowsmediavideo export plugin
    this is not normal...are you sure that you exported only 7 seconds?
    Aristotelis Bafaloukos
    BEng (Hons), MSc, MBCS
    Ctrl+Alt+Delete
      indeed, 100% sure
        what bitrate did you set for video and audio
        what display size will the wmv be?
          for 7 seconds with max bitrate (20.000) and max resolution (1920x1080) it is not possible to reach 210MB...
          20 maybe?
          Ctrl+Alt+Delete
            its 200mb, not sure how its getting to that , but it is, the bitrate is 192kbs
              can we see a screenshot of the windows media export settings used
              also a screenshot of resulting file properties from windows explorer right click/properties menu
