I've got two Edius 3's (1 used for digitizing & 1 for cutting & output). When outputting to file via the Express Wizard, the broadcast setup doesn't offer the "Select a Previous History Setting"... anybody ever had this before?
Edius Pro 3 Output History Settings
nope, i output about 300 separate shots as MPEG2's per project and it doesn't register any history, that's why i keep transferring projects onto a network server and then outputting from the PC with the Edius software installed. I've got a complete re-install planned...
is the radio button pushed? the one belonging to the historyAnton Strauss
Originally posted by natalie View PostI've got two Edius 3's (1 used for digitizing & 1 for cutting & output). When outputting to file via the Express Wizard, the broadcast setup doesn't offer the "Select a Previous History Setting"... anybody ever had this before?
Is there history there but it is greyed out or is it empty?
When you are outputting these files you are going through PCE?
Just did a complete re-install - Windows OS & Edius Pro 3, Procoder 2 etc to sort out other issues... still no history settings. If i output a file from the timeline, and then try doing the same, it does not register any history settings. The settings list remains blank. Not sure what a PCE is?
thnx,
[email protected]
