My slow motion montages have lots of clips and I can't seem to find away to apply it in one go. If I highlight all and go to Clip> Duration it only acts on the first clip. Around 50 speed changes one a a time is laborious. Any ideas welcome please.
Slow Motion on multiple clips
Sequence in out and put it in the time line or in a new seqeunce and aplly slowmow. Instant slow motion to all the footage.Steve
SR - thanks for the response but I really can't understand your suggestion. What have sequences to do with it and what is "Instant slow motion", is it a filter I have missed? Only way I know is Alt+U then change duration which only works one clip at a time even if many are highlighted.
Maybe I'm a bit thick so can you please explain it in more detail.Barry Weare
BW Videofilms, Berkshire UK
Edius 5.5, Win7 Pro 64bit, 16GB RAM, Intel Core i7 2.8GHz, NVIDIA GeForce9600GT, 5x 1TB SATA II (24/7 WD Enterprise type) with 4x in Raid1 for video, 1x for system/utilities.
Barry
Create a new sequence, do your montage in the sequence, all at normal speed and then add the new sequence to your main sequence and put the slomo filter on it.
Another way is to set in and out markers on the area, right click and render and add to timeline and apply the slomo to the file that is produced
Another way is to buy a contour shuttle pro and assign a button to perform Alt E,2,5,enter. (for 25%) You then just select each clip and push the button.
