Noise (Grain) reducer
  • Noise (Grain) reducer
    Is there any Edius plugin to reduce grain noise, or as standalone perhaps?
    Alex
    Median filter in Edius...
      motion blur set to 30% will remove most grain, no good if there is lots of camera movement
      if there is no camera movement at all such as a person taking at a lectern, you can go as high as 50% and eliminate all grain
        Hi,
        Try Neat Video which is a plug in for the free Virtualdub programme.
        It samples a few seconds of the video and then 'smooths' out the grain.
        Like most of the Virtualdub filters - it is very slow, but the results are very good.
        It doesnt work too good on panning shots.
        Keith
        Dual 3.06 Xeon, 2Gb memory, NX card, Edius 4.6, Procoder 2.
          cool, didn't know that one
          GESTOS PRODUCTIONS
          www.gpvideo.com.au
            Great, I like the Motion Blur 25% - thanks for that.
            Barry Weare
            BW Videofilms, Berkshire UK
            Edius 5.5, Win7 Pro 64bit, 16GB RAM, Intel Core i7 2.8GHz, NVIDIA GeForce9600GT, 5x 1TB SATA II (24/7 WD Enterprise type) with 4x in Raid1 for video, 1x for system/utilities.
