Hi guys,
Using Edius Pro to edit a VOB file I've imported. The original video says it's using channel 6 for sound. If I play it in Edius it sounds perfectly balanced. However, now I've added my titles and try to export the sound is much lower...whatever I do I can't get it right. I'm exporting to MPEG and it's converting it to Stereo...I think this is the problem.
If I raise the whole volume the ambient sound is unbearable. Any tips?
Regards,
Tony
Regards,
Tony
