Audiocard for Edius
    Originally posted by swsw1550 View Post
    Hi,
    just noticed the thread about the Audio card, go with the ESI Julia, I am using one of these cards and they are great, you can also reverse the inputs on them, Top Card, great Sound.. Also supports every operating system i.e xp, xp64, Vista 32 and 64 bit as well.
    Cheers
    Hi Steve
    I can only find beta drivers for Vista, and they seem old? Is there another place to find them that ESI's official website?
    /Ulf
    Best regards * Ulf * Denmark
    mail to me
      ... but look out for the drivers, the new ones only works properly with vista.....
      I have Delta cards running on XP machines with the latest drivers without any problems.
      They work just fine with Edius as well.
      I find the M-audio cards very clean and very stable
        Ulf
        Hi Ulf,
        This is the link to the ESI Julia Drivers that I use and they are the Beta ones, they do work great and also with EDius, Never had a problem with them
        even with pro Audio software. http://download.esi-audio.com/?w=esi&p=6&g=1&l=en
        cheers
          Thanks Huw and Steve :-)
          mail to me
            Hi, then you are one of the lucky ones, I know people too, running the newest drivers on XP machines without any problems, but I also know the opposite...I have been in contact with M-audio support, and they said there is a problem.
            A computer with a lot of stuff in it :)
            • #21
              ESI Julia:
              No mic inp.
              then you will need a preamp or mixer for mic´s with [email protected]
              JoiCam´s
              And more
              • #22
                inputs
                it has two inputs, plus a midi plugin cable,
                Cheers
