Some PSD and TIFF's won't import to bin
  • Some PSD and TIFF's won't import to bin
    Running 4.61 and some PSD and TIFF stills open to the bin, but others won't. The ones that won't open are the ones I've resized in PS at 720 x 1028 SD. Edius doesn't like something or is not opening the stills. I get an error message. Anyone run across this recently? Thanks.
    Tom
    Tom Koveleskie - Director/Producer/Editor
    Quarter Town Films - Independent Feature and Documentary Films.
    Edius 8 WG with HDSpark, AMD 8 core FX 8370 Black Edition 4.3 GHZ, MSI 970A Krait Edition, 16 GB Patriot DDR3 1333 MHz RAM, EVGA Nvidia GTX 780 TI graphics, Win 10 X64.
    Can you zip up some problematic images and attach them here?
      A while back I was having trouble with graphics made in Photoshop CS2. Edius (4.6 and 4.5) started giving me an error message that the files were not compatible. After resaving - and renaming - the files (.psd format for me) in the older Photoshop Version 7, they worked fine. I am guessing there was something in CS2 that Edius didn't like.
      ____________________________________________
      Primary System
      Asus P5K64 WS, Intel QX9650, Quadro FX 1700, 2GB of OCZ 1333 Platinum DDR3 RAM, 2 x 20" Wide Viewsonics, Windows XP Pro, Edius 5, HDStorm, Seagate Barracuda ST3250310NS 250GB 7200 RPM SATA 3.0Gb/s Hard Drive, OCZ600GXSSLI 600W ATX12V SLI Power Supply
      Field System:
      Spartan S1730E, 4 3.6GHz NVidia Chipset, 1GB RAM, DVD+/-RW, Win XP Professional, Edius 5, 2 SATA HDDs with RAID 0/1 60GB 7200
        make sure that your images are in RGB mode 8 bit.... Edius cannot open CMYK
        Aristotelis Bafaloukos
        BEng (Hons), MSc, MBCS
        Ctrl+Alt+Delete
          CS2 has always worked fine for me.
          Andrew Pinder
          www.chpv.co.uk
            Thank you very much.... this was the case. A few of the PSD's and TIFF's the client gave me had a CMYK profile. 99% were RGB so this threw me a curve.... Thanks again.
