Audio and Transparency Nodes
  • Audio and Transparency Nodes
    Why when I "replace" a clip on the timeline, either audio or video, do the transparency nodes or the audio nodes get trashed? Surely the advantage of replacing a clip, and leaving, say, a crossfade in place whilst you do it, is lost by removing your carefully adjusted transparency settings or audio adjustments: should be renamed " Replace and Destroy"
    Just spent 4 hours carefully copying 600 nodes - mmmm, what joy.
    Never mind, going to watch "What about me?" 1 Giant Leap at Atzaro in Ibiza tomorrow - so I don't really care - just like to grumble.
    Paul
    Yes it would be great if "replace" in Edius worked exactly like "replace" in AfterEffects.
    Andrew Pinder
    www.chpv.co.uk
      well said
      Paul
        Have you tried using the "Replace Parts" <> "Clip"!
        Works here without changing the nodes on the transparency but does replace the audio, pity.
        Regards Barry
