Detecting Scenes with edius 3
  • Detecting Scenes with edius 3
    hello sorry if posted to a wrong sections :s i'm new here hehe
    my first day using edius and ok this is the prob it's really annoying to try to cut scenes from a long video with this in and out it takes toooo much time. So is there a way to detect the scenes from a video file (mpeg) with edius? Or any 3rd program maybe? And is edius detecting scenes when you capture? or ir doesn't have this ability at all?
    *i'm talking for edius pro 3*
    Edius3 detects scenses while you capture, providing you have this option enabled in application settings/deck settings
    it only works if you capture via firewire
      i have allready captured many hours is there an other way to split the whole video in scenes? :/
        no....................
          no? why no? anyway thank you very much
            try
            Try hdvsplit for mpeg2 or handysaw for avi =)
              thanks :D hdvsplit works nice
