I was reviewing some lightning footage and saw a number of bolts going different directions in a split second during normal playback. When I tried to find the individual bolts (to get a still frame) by toggling through a frame at a time I didn't see all the bolts - I only see all of them on normal playback speed. Why is this? Is this a top field first field order thing or something related to HDV? Thanks!
Isolating a lightning still frame
Jim Edds www.ExtremeStorms.com
Edius 5.51, I7 980x Hex Core, 3.33 GHz, 12GB DDR3, HD Spark, 250GB SSD, Win7 64 bit, 4x2TB RAID 5 eSATA array (200-225mb/sec), 4 hot swappable internal SATAII misc.. drives; Cams: Panasonic AG-DVX200, Go Pro; Edius 5.51/HP 8710W & 17 in mid 2010 MBP/Adobe CC suite.Tags: None
Yes, you are exactly right - if you are viewing your clip in your player monitor, it will by default only be showing you one field set at a time when scrubbing. You need to go to App settings, Playback, and tick "show correct frame when scrubbing".
See if that works :)When I go out, I wear my EDIUS T-Shirt.
humm, that didn't work. I'll keep messing with some settings.Jim Edds www.ExtremeStorms.com
Well not exactly mattmatt...
The bolts only appear on a single field, and unless you pause on the correct one you only have a 50-50 chance of seeing it. (or not) This also applies to camera flashes.
To properly find the bolt, pick View>Pause Field>Frame.
Getting a decent still will be another challenge!
You will also see both fields in a Progressive Project.Rusty Rogers | Films
It worked! Thanks a bunch guys!Jim Edds www.ExtremeStorms.com
