Often when I am working on the timeline and playing the last clip Edius will annoyingly loop back to the beginning of the project and play from there. This doesn't happen every time I play the last clip, in fact I'm not quite sure exactly how it happens! Is there a setting I have missed?
Looping back to start of project
I have the same problem. It happens whether you press play or the spacebar. Once the playhead reaches the end of the last clip it jumps immediately back to the start of the timeline. Edius has always done this (at least since 3.0) and SpeedRazor did it before that! I just assumed it was something to do with the way NLEs worked, and have learned to live with it. Annoying nevertheless.Andrew Pinder
www.chpv.co.uk
Playback settings are I think the default - see attached file.Attached FilesAndrew Pinder
www.chpv.co.uk
So Biopic, I am not alone!
Playback is set to 5 frames buffered before playback and Continue playback when editing is ticked.
Just tried to create it by starting playback on final clip with spacebar and then monitor start control and it stops OK at end of clip. However earlier when I was adding trimmed clips to the end of the timeline using the insert to timeline key sometimes it shot back to the start, but not every time.
Sorry but it's a bit difficult to pin down so I'm pleased Biopic is with me or I'd think I was going mad.Barry Weare
BW Videofilms, Berkshire UK
Edius 5.5, Win7 Pro 64bit, 16GB RAM, Intel Core i7 2.8GHz, NVIDIA GeForce9600GT, 5x 1TB SATA II (24/7 WD Enterprise type) with 4x in Raid1 for video, 1x for system/utilities.
Just figured what happens - as last clip is playing toward the end I try to pause it with the space bar, if I mistime it and press spacebar at the actual end of that clip it goes back to start. Can I stop it doing that?Barry Weare
Yes, I thought that might be what was happening (mistimed spacebar at end frame). It was either going to be that, or accidentally hitting CTRL-Spacebar when holding down the SHIFT key for buffered playback.
Not much can be done to remedy that without a software change - time for a feature request?
Yes Barry that is exactly the point. I don't want it to go back to the beginning unless I tell it to (especially annoying if the timeline is say 2 hours long).Andrew Pinder
www.chpv.co.uk
Yes I do that sometimes, but other times I forget and it's a pain.Andrew Pinder
www.chpv.co.uk
