Sometimes I prefer clips on two tracks (e.g. 1VA & 2V) just so I can see what's going on! The only way I know to dissolve between clips on two tracks is to use the fade in/out tool or manually fade using the blue line in the white area. However both these methods are unsatisfactory because the images are actually fading to/from black and the result is the image going dim through the dissolve.
Am I missing a trick here or is this normal for Edius?
