Glad everyone is enjoying Macs along with EDIUS hehe
Geoff, I'm pretty much lost on your issues, that is the only way I would figure out what the problem is would be to actually see your system. Something must be wrong, I haven't really had any major problems that you are having.
Not much, Apple has made it very easy that even a non techie can do it. Just make a partition as big as you want, if you plan to install alot of Windows applications leave room for it. I would give it at least 250GB since you have such a big OS drive. It's upto you. Bootcamp only creates the partition for you and formats it to FAT32, once it creates it, Bootcamp asks you to insert the Windows CD and then you restart. When you run the Windows installer, you will have to format to NTFS (use Quick Format, takes less time) and then off you go.
Booting to Windows or OSX is easy, all you do is hold down the Option key to before the Mac sound comes up and it will give you the option of picking either OS. You can also setup the default to be Windows (it is OSX by default, obviously) so when you start your computer it will boot into Windows.
Originally posted by hedleyw
View Post
