DVD Quality
  • DVD Quality
    Hey All,
    I just did my first dvd with chapters in Edius and I must say it works quite well. I video dance recitals and this works great for those folks that only want to watch their little darling without having to wade through the entire event.
    My question (though I believe I know the answer) is this:
    Recitals are typically over two hours and the one I just finished is closer to 2.5 and I notice the quality of the video is not as good as I am used to getting. Will I be forced to put these on two discs or is there something I can change in my Edius settings prior to burning.
    Thanks as always
    I would put in on 2 disks
    remember that a DVD case that holds 2 disks costs basically the same as one that holds 1
    all you are up for is the cost of an extra blank disk per order
      Anton is right, but if you must put it on 1 disc here are the settings you should use, and only on Procoder 2 or 3
      Master quality
      VBR 2 passes
      minimum 2500kbps
      average 3885kbps
      max 5270kbps
      (udner advanced tab) Intra DC precision 10
      The result are very acceptable.
        As I don't have Procoder 2 or three I'll go the two disk route.
        Thanks for the replies!
          If it's 2.5 hours, that should still be able to live on a single dual layered disc with acceptable quality..
            remember that DVD Creator has some advanced settings for quality such as highest quality and CBR versus VBR
