I’m currently using the NX with Edius 4.2 (PAL Aust.) and have finally got around to building some projects in HD (shot in HDV). With one TV commercial just completed and a half hour program in its early stages I’m a bit concerned with HD to SD conversion. Currently the TV stations will only accept SD and therefore I need to convert my finished projects to SD for delivery. There is also the need to provide content for DVD release.
My initial testing has been a bit disastrous. Any HD vision that I convert from Edius or Procoder to SD has lost sharpness, has color space degradation and bad interlacing effects. These are most notable on faces during IVs.
Is there a wrong and right way to do this?
Does a good conversion require extra hardware?
It would be good if my final product (after conversion from HD to SD) at least looked better than SD produced products.
