I won´t to move a clip frame by frame in timline by using keyboard not the mouse is that possible?
move clip frame by fram in timeline
sure is possible, use the , and . keys
but first, you must press the correct keyboard shortcut for roll mode, in my case F8 but maybe different in your case
alternatively, ctrl+click the left and right edge of the clip so the clip has green handles, then press , for 1 frame to left and . for 1 frame to right
shift + , for 10 frames right
shift + . for 10 frames leftAnton Strauss
to created a shortcut key for nudge
go to customize, keyboard shortcuts, find "Trim-select roll"
apply an available keyboard shortcut, in my case F8
to use, select any clip, press F8, then use , or . to nudgeAnton Strauss
That is what Anton explained .
So do it?Steve
sorry no effect
i've done all this and tried with sync mode off and on - it just trims the end of the clip in the timeline that's been selected - not moving the whole clip without trimming...plz anyone explain more precisely - 10x in advance...
Look at the picture maybe it will helpAttached FilesSteve
and to speed the process, I made a keybord shortcut for "Trim-select roll" (F7)
then all I need to do is push < or >
shift + > moves 10 frames in one hit to right
shift + < moves 10 frames in one hit to leftAnton Strauss
Mine is F4 . It is easier with the shortcut. :)Steve
