ASUS Striker II Extreme Motherboard for SP system
  • ASUS Striker II Extreme Motherboard for SP system
    Will this be good for Edius SP? I believe is one of th newest from Asus so its not on the approved list yet.
    Here some specs:
    Intel Socket 775 Core™2 Extreme/Core™2 Duo/Pentium® Extreme/Pentium® D/Pentium® 4/Celeron Processors
    Compatible with Intel® 05B/05A/06 processors
    Support Intel® next generation 45nm CPU
    Chipset NVIDIA nForce 790i Ultra SLI
    Memory 4 x DIMM, Max. 8 GB, DDR3 2000*/1800*/1600*/1333/800 Non-ECC,Un-buffered Memory
    Dual channel memory architecture - supports NVIDIA® SLI™-ready technology
    Expansion Slots 2 x PCIe 2.0 x16 ,support NVIDIA® SLI™ technology, at full x16, x16 speed(blue)
    1 x PCIe x16 ,at x16 speed(middle)
    2 x PCIe x1 ( the PCIEx1_1 (black) is compatible with audio slot)
    2 x PCI 2.2
    Scalable Link Interface (SLI™) Support NVIDIA 3-way SLI graphics cards (triple at x16 mode)
    Storage Southbridge
    1 xUltraDMA 133/100/66/33
    6 xSATA 3 Gb/s ports NVIDIA MediaShield™ RAID Support RAID 0,1,0+1,5,JBOD span cross Serial ATA drives
    JMicron® JMB363 PATA and SATA controller
    2 xExternal SATA 3.0Gb/s port on back I/O (SATA On-the-Go)
    It'd work with SP SDI with full functionality, but not with standard SP boardset.
    SP SDI boardset is PCIe + 32-bit PCI
    SP boardset is 64-bit PCI + 32-bit PCI
      Will it work for NX Express?
      ASUS ROG Strix Z490- E, i9 10900 @ 2.8G, 32GRam, Windows 10, NVIDIA GeForce GTX 1070 Ti
        Yes, as NX Express is 2 x PCI-Express x1 cards.
