I tried to send a 53-minute video out to DV tape using two different cameras, and Edius kept dropping signal within the first few minutes. I noticed the hard drive the project is on is almost full; could that be a factor? What else can I check?
DV tape out not working
Originally posted by kwshaw1 View PostI noticed the hard drive the project is on is almost full; could that be a factor? What else can I check?
Clean out as much as you can and defrag the drive.
Or Transfer the finished file to another drive to export from.
Graham
Kevin,
My single drives have a time playing more than one video track.
Quick-fix for a full drive...
Render a DV file of the timeline to the system drive (or another)
print to tape...
if there's room, move the new file to your external drive.Rusty Rogers | Films
Originally posted by Rusty View PostRender a DV file of the timeline to the system drive (or another)...Last edited by kwshaw1; 06-11-2008, 03:47 AM.Edius 6.5 on Lenovo W520 laptop: Intel Core i7-2720QM @2.2 GHz, Nvidia graphics card, 8GB RAM, Windows 7 Pro 64-bit. Canon Vixia HF-G10, three Sony HDV video cameras and one Canon 7D.
Count yourself lucky- you got it to work occasionally-- I'd settle for flashes of my project on tape out-- now I'm re-formatting AGAIN, re-install Win, RE Install Edius- this is the fourth time-- keep getting something different!-- Oh what fun!-- maybe I'll get to rest in a couple more days-- I really miss the solid workings of the old Canopus products--
To give credit, the dongle works-- at this point I can think of other places to put itMain System- HD Storm + Edius 7 Pro
Win 7 (64),Asus P6T Deluxe v2 - Intel I7 - 12 G ram Gforce GTX 970 - 6 T internal-- 12 T Drobo Sata connection
Secondary System- Edius 6- Win XP, Intel DH55HC i5 4T storage, 4G ram, Gforce GTX 260, , ADVC110
Hi Kevin
It certainly could just be the drive is slowed down by being almost full....however being a laptop I wonder if anything is interfering with the process....by polling the bus or going to sleep....maybe check power management settings of your devices....just a thought.
Dave.Main Editor - Edius 8.53 AdobeCC Mini Monitor 4K Intel X99P SLI Intel Core i7 6800K CPU Gigabyte GTX980 SanDisk Ultra Video SSD 1XINTEL System SSD 16GB Kingston DDR4 2400 RAM VisTitle 2.8 Onboard Sound 10GBE LAN WIN10Pro 64bit
www.nakedeyedv.com
Enditall
I used to use a program called Enditall on my old laptop.
If I was using it to edit - fine but if capturing or outputting I had to run Enditall first to get anything to work properly.
This was on XP so am unsure if it wil work if you are running Vista / W7.
Originally posted by Ed122 View PostCount yourself lucky- you got it to work occasionally-- I'd settle for flashes of my project on tape out-- now I'm re-formatting AGAIN, re-install Win, RE Install Edius- this is the fourth time-- keep getting something different!-- Oh what fun!-- maybe I'll get to rest in a couple more days-- I really miss the solid workings of the old Canopus products--
To give credit, the dongle works-- at this point I can think of other places to put itI7-6900K, X99 Taichi, Geforce GTX 1070, Corsair RM850X, Corsair H100 IV2, Windows 10, Edius WG 9.30
I had this print to tape problem occur a while back as well. I found that if I had my USB wireless adapter plugged in and running in the background, it would interrupt the print to tape process. I would make sure that you have any unnecessary process stopped before you print to tape. Go into processes and take a look at the list first before outputting to tape. This corrected my problem.Tom Koveleskie - Director/Producer/Editor
Quarter Town Films - Independent Feature and Documentary Films.
Edius 8 WG with HDSpark, AMD 8 core FX 8370 Black Edition 4.3 GHZ, MSI 970A Krait Edition, 16 GB Patriot DDR3 1333 MHz RAM, EVGA Nvidia GTX 780 TI graphics, Win 10 X64.
I think at this point it would be great to have some more info if the system is indeed adiquate to handle anytime realtime in general.
Could you download this little free app: http://www.thesycon.de/deu/latency_check.shtml
test 1) let it run for a while without Edius, remember to check value's once a while, and reset (but note down) if any high value, normally in red color, and repeat this for several minutes.
test 2) reset the counter, then start Edius and use it for a while check reading periodically.
if test 1 fails, you system is inadequate to perform any realtime delivery, when using Edius it will surely fail.
if test 1 passes, and test 2 fails, your system (software) might be set up right, but hardware through puts are insufficient.
o.k. before we get carried away, please test and report findings ...............
remember, the test app will not report which hardware / software is giving the problem, it only indicates there is a problem and you need to search manually for it.
