How many CPUs does Edius use?
  • How many CPUs does Edius use?
    Is there any advantage in having more than 2 cores using Edius?
    I have a Core 2 Quad, Edius recognizes 4 cpus at the startup but I noticed in the task manager that it doesn't use more than 2 Cores.
    If it doesn't use more than 2 right now will it use in 4.5 or in future versions?
    Julian
    You're perfectly fine with a single Quad Core CPU. Maybe by version 6 it will be fully taken advantage of.
      Julian
      It's great to have a quad, until you realize that you are not utilizing all of the cores.
      Anything is possible after 4.5. I would venture a guess that version 5 will have a lot of product inhancements. Core useage, possibly.
      If you need to use all 4 cores, Premiere CS3 uses multiple cores as does AE CS3.
