Edius v4.60a: Edius crashes with using Letter Box
  • Edius v4.60a: Edius crashes with using Letter Box
    Hi,
    Yesterday I tried to upgrade Edius from version 4.24 to 4.60a.
    After installation I tried to load some project of Edius v4.24.
    After loading Edius crashed after choosing first sequence.
    After longer time I've found out repro...
    REPRO:
    1. Unzip file EdiusTests.zip
    2. Run Edius 4.60a
    3. open project EdiusTests/Exception_01.ezp
    4. There is only one sequence called "Sequence1". Click clip called "Color Matte"
    5. Open the "Information Palette". You will see two filters: "Region" & "Combine Filters"
    6. Select "Combine Filters" filer and open its settings
    7. Click on "Settings(1)" button (of the "LetterBox" filter).
    8. Uncheck "Normalize" checkbox at the right-top of the screen
    WRONG:
    Edius will crash and disappear.
    SHOULD BE:
    Edius should not disappear. Changing "Normalize" settings should be possible.
    NOTE:
    This case occurs with checked "Soft Edge" option with "25" value.
    If you uncheck "Soft Edge" checkbox first and uncheck "Normalize" checkbox then Edius will work properly.
    I'm enclosing zipped sample project that causes Edius crashing & report of loaded libraries.
    Is it any chance to fix it?
    Regards,
    Adam
    Koala Wideofilmowanie
    Edius 4.24 with NX Expansion Kit Hardware - Duo 2 Core with 2.4GHz CPU, 1GB DDRAM2, ASUS P5LD2/C R2.0,
    Gigabyte ATI Radeon X1300 Video Card
    1TB HDD SATA (summary of 3 HDD)
    May I suggest that you complete your projects in 4.24 and start new ones in 4.6.
    There is something wrong with 4.6, it does display errors when asked to open earlier version projects - especially if you use an NX card
    Paul
      I would install the latest version, 4.61
        Thank you for your suggestions.
        I've downloaded Ediu 4.61 version.
        I need to load previous project made with Edius 4.24. There are few visual effects too complicated to create once again.
        Well, If 4.61 wont work then I try to create my effects again. I'll inform you about results soon.
