Hi,
All sequences I export from EDIUS 4.xx via ProCoder 3 or ProCoder Express to mpg, avi etc. - doesn´t matter which format I choose - show a distinct and annoying flicker in the dissolve transitions - whereas the same transitions run absolutely smooth when played directly from the completely rendered timeline on both PC monitor and external LCD-TV (and on the videos exported to tape).
The exported transitions (standard 2D dissolves between 6 and 30 frames) flicker, i.e. they look like an old movie with its distinct variations between lighter and darker frames.
I work with flawless high end equipment and have tried a lot of avenues to solve the problem - to no avail so far.
Any idea what could cause it?
Regards,
Peter
Regards,
Peter
