Create NTSC DVD from PAL mpeg
  • Create NTSC DVD from PAL mpeg
    I have a PAL project in Edius that I burned to DVD. I have been asked to provide an NTSC version of it. I still have the mpeg files from the Temp folder Edius made when it created the DVD.
    What is the best process for making an NTSC DVD from them? Can I simply drop them into an NTSC timeline and then make a DVD?
    Thank you.
    Joe Shaw
    Freelance Director/Editor
    I did something similar recently, by ripping a PAL DVD with Let's Edit2 and then using Procoder to convert the file to NTSC and append some more NTSC footage. In Edius Capture/Disc Capture should be able to rip the dvd file, or if you already have the file then procoder should be able to handle it.
      This might be of some help
      Tony
      Tony
