When I fade out to black. How can the Audio fade with it too? Without doing it manually. When I edited with REX adn STORM edit. I faded to balck and so did the AUDIO. Cheers
FADE out BLACK. AUDIO to FADE too?
If you add a default transition, and audio video is LINKED (ie, it is not grouped nor unlinked) and the upcoming clip is also the same way, an audio transition is added once you add a video transition.
PS. Please don't capitalize words in the subject line, I'm sure everyone here can see what you said already :)
click the down arrow of the fade out or fade in tool on the timeline tool bar and select fade audio
or manually do it with the rubber banding, my preferred methodAnton Strauss
Originally posted by GrassValley_MD View PostIn July this is going to be very easy ;)
P.S Sorry but I had seen July mentioned...Main system, Supermicro X8DAH+,Dual Xeon X5680 cpu's 24 cores,2x1400watt power supplys,SC747TG-R1400B-SQ Case,192GB 1333mhz ECC Registered ram,8 x 480GB Intel 520 SSD drives,Windows 7 64 bit ultimate, GTX 670 4GB ,2 x Sony BWU300S Blu-Ray burners, 1x Sony DVD burner,LSI 9266 Raid Controller with Cache vault & fast path Lic, ESI MayaE Audio,HD Spark,Blackmagic intensity Pro,TMPGenc 5,Episode Pro 6,Sorenson 9 Pro,Alcohol 120 V2, Edius 6.53,Dell 27"LCD,HD Spark, Powershield 3000VA UPS.
Originally posted by swsw1550 View PostMike what do you mean in July, is this when we will see 6.0
P.S Sorry but I had seen July mentioned...Anton Strauss
yes, Mike's post was from 2007 so it would have been leading up to Edius 4.5Anton Strauss
