Shortcut for audio fade
  • Shortcut for audio fade
    Hi
    I remember to have read somewhere reg. a shortcut that would fade audio in or out if your TL indicator/cursor would be in the almost end or start of an audioclip. Anybody know where to find this again?
    /Ulf
    Best regards * Ulf * Denmark
    mail to me
    Settings > Application Settings > Customize/Button > Under timeline, add 2 new buttons for Fade-in/out.
      Yep, then use the Pull-down to fade Audio only!
        Thanks guys :-)
        /Ulf
        mail to me
          note that the fade buttons don't work in most cases
          (most cases = when the rubberband has existing nodes = in my case, all the time)
            Strange because it works here?
            Can you give me steps to reproduce?
            Is this with mapped audio or on an av track?
            I just did it on a AV track just added some nodes and did the start fade with the button.
            Left the playline so you can see that the fade /node is at the exact position.
              ooops, it did not work for me in previous versions, so I removed the buttons thinking that this is how it was designed and as a result was of no use to me
              I tried again now with 4.61 and it does work regardless of how many audio or opacity nodes are present
                He he. Fixed and Anton missed it. :)
                  getting better all the time
                  the problem is that Japan does not make a full list of what they fix, I am not sure why, doesn't it look better if more items are shown as fixed?
                    I think it would be great.
                    STeve
                      We have fought that battle for a long time now. And some of the undocumented fixes turn out to be significant ones.
                        yes, just like this one, what a time saver
                          You should be able to assign a keyboard shortcut for these two. Another time saver.
                            I need to get a keyboard with more keys :)
