Help with playing .vob files
  • Help with playing .vob files
    Hi
    I have a dvd recorded on a Sony dvd recorder.
    I have copyed the vob files into the computer and
    inserted them on edius 4.6´s timeline.
    When playing back, the files in the preveiw window turns green.
    Is there some sort of option I have to turn on or off ?
    Sebastian
    1. go to plugin settings/mpeg exporter and make sure "Don't use PTS" is ticked
    2. insert DVD in drive, click capture, then disccapture
    report back your findings
      Bingoooo,
      Its working now.
      back to work
      Sebastian
        Geez Anton
        How do you know all this stuff??!!
        Intel Quad Core Extreme 3GHz/12M, 4Gb RAM, 2Tb Hot-swap (ARAID), NVIDIA GeoForce 8800 GTS, Edius Broadcast 4.61 / Edius 5.5, Procoder 3, DVDit Pro HD, Sonicfire Pro 5, Mercalli, Vitascene, Adorage. TwinPact 100, Pegasus, TMPro. VirtualDub
          Originally posted by TrackRanger View Post
          Geez Anton
          I read this newsgroup and I remember what I read
          I also try lots of things until they work
            All worked fine but audio was out of synch. Is there a way to capture so audio is in synch?
            Thanks,
            Ara
              I have experienced the same on longer files such as 60min with ac3 audio, I am still looking for a solution, I will post if I find something that works
              meanwhile, to avoid this I capture via component from DVD player, quality is great
                hi anton,
                i always drag n drop the vob files in my time line(after i copy the vob files to internal hardisk)..i can edit it straight away..a bit slow off course.. but no green screen...sometime i just encode vob file to canopus HQ avi with procoder so that i could use it in my time line in RT.
                MOtion Candid CApture
                www.houseofmocca.com
                Indonesia
                  when you use DVD capture, the vob is correctly joined from its various parts and all access baggage is deleted such as multiple audio and subtitle streams which can all be part of the vob and will give you problems if they are
                  a vob file is not a video file, it is a container of many files including video
                    I always convert .ac3 to .wav before I load the .m2v and audio together and sync them in EDIUS. Google for "BeSweet". I also use DVD Decrypter (Again, google) to rip non copyrighted DVD's into demuxed versions. Sometimes I have trouble with DVD's from set top recorders...
