I'm using 4.62 but am confused about the Multicam Mode Sync Point function. I have 5 clips (whole tape clips) from 3 cameras. I'd like to place them on 3 lines and have Edius sync the 3 lines by time/date. It's supposed to be able to do that isn't it? I can't seem to figure out how from the finely crafted 4.5 user guide, but that's probably just me. A search of this board didn't reveal the secret either. Is there anyone here who can help me use this function? It sure would be a nice start at getting the clips in sync.
Fred D
Win 7 Pro-64 bit, EDIUS Workgroup 8.5, Intel Ivy Bridge i5, ASUS P8Z77-V-LK, 8GB Kningston DDR3, Pioneer BDR-209UBK, EVGA NVIDEA GEForce GT630, Corsair TX750M 750w Power Supply, 4 WD Black HDD for 3.15TB, ACEDVIO, Spark HD, eSATA controller, ANTEC 300 case.Tags: None
Having never used the function I'm no authority...
But unless your cameras are all world-clock synced, there's not much point. (imho)
Camera time will get you in the same ballpark as eyeballing the clips.Rusty Rogers | Films
Thanks for your thoughts Rusty, and no the three cameras are not world-clock or any other common clock synced. I have 4 sessions (shot 7 days apart) each with 5 tapes to deal with. If I can establish the clock offsets for session 1, I'll bet I can sync sessions 2-4 more quickly than just using my usual techniques. Of course that's just my opinion.Fred D
I haven't used multicam mode in a few months and when I did use it, I had the camera's timecodes sync'd which made live a great deal easier, but I think you can still have Edius sync up the clips.
What you will need to do, however, is figure out the offset between the clocks, and then adjust the start timecode of all but one of the cameras (which becomes your master timecode). When you click on a clip in the bin, go to Properties, and then the Video tab, you can adjust the Start Timecode. After having made the adjustments on the clips you want to edit, add them to the multicam timeline, and Edius will position them for you automatically based on the timecode.
You have to set the Sync Point before you drag the clips to the timeline.
Once you have Sync Point set, then drag the clips to the timeline and they'll line up.
Note that not all cameras store the date/time stamp in a way that EDIUS can read it. Set the information display in the Application settings, Timeline to show the date/time - that'll tell you whether your camera's date/time data is being read/stored.
Ah Ha! A clue to the problem: "not all cameras store the date/time etc." Think I've tried all possible ways to use this function without noticable results. I will check tomorrow as you suggest, just shut the system down after working on it a good part of the day, not about to fire it up again now. Thanks for the info.Fred D
Considering that one of the 3 cameras is deliberately started late to cover the gap times when the other 2 cameras must change tapes, starting all 3 at once is not an option. Of course I do sync using the audio wave forms, but in fact they can be very different according to camera placement and sound source. Finally, yes I do use camera flashes for syncing as well. This isn't about the absolute ability to sync, it's about using a function which might set up a starting point and save a little time.Fred D
Fred when cameras are set to free run (if your cameras have this option) it doesn't matter when you change the tapes, the TC will allow you to correctly match the cams with each other. You just need 2 people to set the TC to 00 and enable free run at the same time. You might be off a frame or two, but that can easily be matched.
I've tried Freerun once, it was very good...but I'm so used to using audio and flash that it doesn't really matter to me anymore, but since you switch tapes, free run might come in handy. Our cameras shoot 276 mins continuously so this is why we don't have much trouble with it.
I'm lucky to have cameras with glass lenses instead of pinholes, no free-run here. Syncing the clips is not really a problem, just thought I'd like to try this EDIUS feature. It might save a few minutes, then again maybe not. Really expect to find that my GL-1 and HV-30 and Panny "whatever" do not present the date/time info in a manner that pleases EDIUS. Will check a bit further after a shower and breakfast. Thanks for your info Dave.Fred D
Originally posted by GrassValley_BH View PostYou have to set the Sync Point before you drag the clips to the timeline.
Ted
Gordon:
Sorry to have created concern. You are of course correct. I should have typed 4.62 ---oooooops, there I go again, 4.61. Write 100 times on the blackboard, "4.61" 4.61, 4.61, 4.61, 4.614.61, 4.61, 4.61, 4.614.61, 4.61, 4.61, 4.614.61, 4.61, 4.61, 4.614.61, 4.61, 4.61, 4.614.61, 4.61, 4.61, 4.614.61, 4.61, 4.61, 4.614.61, 4.61, 4.61, 4.614.61, 4.61, 4.61, 4.614.61, 4.61, 4.61, 4.614.61, 4.61, 4.61, 4.614.61, 4.61, 4.61, 4.614.61, 4.61, 4.61, 4.61Fred D
Should be frame accurate, assuming you've set the appropriate Sync Point for your clips and there isn't other stuff in the timeline tracks to jam things up.
So all your cameras are timecode-synced? If so, set Sync Point to Timecode, assign the appropriate Camera tracks (the C dropdowns), then select all the clips in the Bin and drag them to the timeline.
